#1 2010-03-03 01:48:59
Superman
Mcamv-Vericut Interface Problem
Installing Mastercam X4 MU2 and having problems with environnent BAT file not being recognised.
Currently running Vericut V6.2 and Mcam X2 MR2 - the interface chook works correctly
I have downloaded the X4_32bit.ZIP file from the FTP site and placed in their correct locations, copied the MastercamX2.BAT file to MastercamX4.BAT and altered the executable path to X4 ( the only change )
But when passing a toolpath to Vericut, it displays an error asking me to set environment variable
What are the correct files for the interface to work ?
The FTP site now has removed these files ?  Did they not work ?
#2 2010-03-16 01:21:36
Superman
Re: Mcamv-Vericut Interface Problem
The problem was in the actual MastercamX4BAT file being called
the old BAT file needed an additional line to set the environments for the Chook to run in X4
