The new function that exports the fixture in separate STL-files (added 6.2.2) is partly a step forward but also gives me trouble.
Some of our fixtures contains up to 2000 parts in the assembly - all of them exported as a separate STL-file whe exporting the fixture through NXtoVericut-Interface.
I know I have asked for this to achieve smaller bounding boxes - that's the good part.
But it's not possible to use the fixture at a spinning lathe table without getting thrown out of Vericut.
If exporting the same fixture "manually" to create one single STL-file it works as expected.
To be able to group the parts in the fixture and export them as for example up to 10 different STL-files should be the best.
Svante Eriksson
System owner
