Of all the changes made to 7.0 there is only one that is a major pain.
If you move the stock form the first to the second operation and the design is invisible,
the design dose not move with the cut stock. So you have to reset the project and start all over.
If the design is attached to the stock. Then why not let it move with it, regardless of visibility?
CAD
I have entered an Enhancement Request on your behalf.
This issue still hasn't been fixed in 7.0.1 and was causing us a lot of problems until I found a work around.
You are correct, it was fixed after 7.0.1 was released. It will be in the next available release.
