Hello,
i can't get my b-axis rotate as it should be on my horizontal 4-axis machine.
On my real machine it is so:
1.When I input a value b the axis is only rotating clockwise.I doesn't matter if the value is positive or negative.
2.It's always rotating clockwise absolute from 0 degrees.
2.When i input, for example b-10, axis rotates 10 degrees from absolut 0 degrees.(But that's not the problem in vericut, because we always program only positive).
3.When i input, for example b350, axis is rotating clockwise from 0 to 350.
I can't get it working on vericut.
I've tried everything in the control settings,rotary tab.
Vericut always takes the shortest distance to go from a rotate point to another and rotates cw and ccw.
How can i set it right ?
chester
I think i got it working now.
Output Intermediate Points switch to yes is the right way.
For automatic programs it's now the way i want it.
But in MDI it's still not showing correct.
chester
