#1 2009-09-14 09:34:04
chestervom
Problem with Dynamic Work Offsets
Hello,
i have build a horizontal 4-axis Machine in Vericut 6.2
It's a MAZAK PFH-4800.
Because when we rotate the part with the b-axis (pallett) our program zero is not automatically go with, if the part is not on the middle on the pallett.
So i write a macro program on our machine called P9993 where we set our G54 every time rotating the part new.
That's working really good.
Now i'm trying to work that with vericut.
I've set the macro Dynamic Work Offsets on the word/adress to G54.Is that o.k ?
The simulation is exact as on my real machine.
The problem is that i give a warning that the axis limit is reached by rotate the part when i turn on to check the axis limits.
But that cannot be, as the axis is long enough.
The other problem is, how can i ignore the variable #20,#108 and the P9993 that i don't get a warning ?
I've uploaded the machine files with a sample program here:
ftp://mastercam:swiss@www.mastercam-cad … roblem.zip
chester
#2 2009-09-23 22:27:48
Re: Problem with Dynamic Work Offsets
This was posted twice. Please refer to:  <!-- l --><a class="postlink-local" href="http://www.cgtech.com/forum/viewtopic.php?f=2&t=1389">viewtopic.php?f=2&t=1389</a><!-- l -->
