#1 2009-08-30 19:48:26
chestervom
Re: Mastercam and cutter comp
Hello,
i try to use the Mastercam Interface and have a problem with cutter comp.
When i have a operation in Mastercam with cutter comp turned on and output the nci to simulate, vericut takes too much material from my stock.
It is the radius size from the programmed tool.
Without cutter comp the simulation is good.
I have nothing in the fields project template or setup template.
Can i make any settings that vericut work right with cutter comp ?
I have VERICUT 6.2 and Mastercam X3 and X4.
chester
