Hi everyone!
Pro/Manufacturing allows the creation of custom cycles so that you can output a custom cycle entirely designed by yourself, however by default Vericut is not able to simulate APT couplet cycles other than the Pro/NC default ones.
After a quick investigation I found the standard cycles defintion for Pro/NC cycles, but I don´t know if such definitions are hardcoded in Vericut source code if they are based in some external ASCII file. My bet is that if they are defined into some ASCII file, then I think that I can define the syntax of my own APT cycles in there besides the default ones, allowing Vericut to simulate them as well.
Any insight how this can be done?
Thx,
Just figured out how to do it:
You have to edit the user file that is used by Pro/NC and Vericut during the verification startup:
Path:
\loadpoint\i486_nt\vericut\proem.usr (Metric)
\loadpoint\i486_nt\vericut\proe.usr (Inch)
There you are going to find these strings, followed by a bunch of code to define Pro/NC couplet cycles:
CYCLE_DEFINITIONS CYCLDEFS BEGIN_CYCLES
CYCLE/TAP,#fedto,#fedupm,MMPR,#rapto
MODALS: cycle_op=on, retract_mode=fedrat, csink_mode=off
$$ CICLOS ESPECIAIS LAB
$$ Ciclo de Broca Canhao - PP DMU70 Evolution - Millplus - MMPM
CYCLE/ BROCA_CANHAO,DEPTH,#fedto,MMPM,#fedupm,#rapto,A
MODALS: cycle_op=on, retract_mode=rapid, csink_mode=off
$$ Ciclo de Broca Canhao - PP DMU70 Evolution - Millplus - IPM
CYCLE/ BROCA_CANHAO,DEPTH,#fedto,IPM,#fedupm,#rapto,A
$$ FIM CICLOS ESPECIAIS
END_CYCLES
RP_CYCLE_DEFINITIONS RPCYDEFS BEGIN_CYCLES
CYCLE/OFF
MODALS: cycle_op=off
There is a plenty of information about how to define these cycles here:
\loadpoint\html\usascii\vericut\about_configuring_for_cycle_simulation.htm
Or in Vericut help "About configuring for cycle simulation"
HTH
