On the Fanuc Control, Tool Length compensation can either be cancelled and applied immediately (causing a motion) or after the motion. By default G43 or G49 is causing a motion, but some machine manufacturers can change this behavior.
To avoid a bad surprise on the machine, the Fanuc Library control was updated in 6.2 to reflect the worst case scenario.
If you have confirmed that this is not the behavior or your machine, you can change the following:
Expand the States, G49 and TurnOnOffGageOffset
Right Click on TurnOnOffGageOffset and select Add/Modify
Remove the word IMMEDIATE from the override text
Repeat for G43
