#1 2008-07-23 16:00:42
ElyW
MasterCam Interface and V6.2 may generate an error
Problem
Installing MasterCAM interface in V6.2 may generate the following error:
  • Set environment variable CGTECH_PRODUCTS to CGTech’s products path
  Reason
The interface was enhanced to require CGTECH_PRODUCTS variable to be consistent with the other interfaces.
Solutions
Define for 32/64 bit installs either CGTECH_PRODUCTS=c:\cgtech62\windows  or CGTECH_PRODUCTS=c:\cgtech62\windows64
  1. As an Environment Variable under System Variables (if you have access) or as User Variables.
  2. Or edit the  mastercamX/X2.bat and add the line in BOLD for either a 32 or 64 bit installation
  • @echo off
    rem Following line references installation folder for VERICUT
    Set CGTECH_INSTALL=C:\cgtech62
    Set CGTECH_PRODUCTS=%CGTECH_INSTALL%\windows
    Set CGTECH_PRODUCTS=%CGTECH_INSTALL%\windows64
The batch file will be fixed in V6.2.x
