How can i get different color for each operation.
Sometimes we run many operation in the same tool.
Configuration-Color-Cut color Table(Only Tool ,not operation)
See VERICUT help "VERICUT-CUTCOLOR Record". This command can force the color outside a tool change. You have to insert the command in your NC program at each operation change
This depends on how you identify an operation. If your post write some kind of comment to mark the start of each operation, you can use this a fixed bit of this comment to automatically set the cutcolor.
Because the cutcolor list is a limited list you need to make sure that this auto setting cycles thru the colorlist.
For that some logic is required, so it's easiest to use a subroutine for this
In my post NX-CAM operations are identified as: ;NX Operation #{number}: {name of operation}
use a substitute rule in the control > control advanced options > substitute > {;NX Operation} substitute by {CycleCutColor}
in Control > Word Format, add the word CycleCutColor as macro
In Control > G-code processing
add CycleCutColor command
add macro CallTextSubName
In the Control Advanced Options > Subroutines
Edit or add a subroutine file
add sub program CycleCutColor
%CYCLECUTCOLOR.SPF
R1=25 ;Number of colors in the cutcolor list
R2=R2+1 ;Counter to cycle through list
IF R2>R1 ;When counter is higher than maximum color number
    R2=1   ;Reset to 1st color
ENDIF
cgtech_macro "SetCutColor" "" R2
M17
For that some logic is required, so it's easiest to use a subroutine for thisIn my post NX-CAM operations are identified as: ;NX Operation #{number}: {name of operation}
use a substitute rule in the control > control advanced options > substitute > {;NX Operation} substitute by {CycleCutColor}in Control > Word Format, add the word CycleCutColor as macro
add sub program CycleCutColor%CYCLECUTCOLOR.SPF
ENDIF
M17
Patrick,
I´m your fan!
paehv wrote:This depends on how you identify an operation. If your post write some kind of comment to mark the start of each operation, you can use this a fixed bit of this comment to automatically set the cutcolor.
ENDIF
M17Patrick,
I´m your fan!
I agree! I'm joining the fan club too!
That is a great tip!
New Zealand Vericut Reseller
I like the idea, going to give a try.
If you prefix the cycle name with a PROC in Siemens, you don't even have to do this:
JM2C
In response to Planet Earth's post;
I followed your lead and got my Fanuc control to change color for every tool path.
Below is my sub;
%CycleCutColor
N100
#801= #801 + 1
cgtech_macro "SetCutColor" ""  #801
IF [#801 LT 25] GOTO300
N200
#801=0
IF [#801 GT 25] GOTO200
N300
M99
Thanks Planet Earth
